DISA
Discussion in '3CX Phone System - General' started by sanketgroup, Aug 16, 2012.
  1. sanketgroup
    Jun 28, 2012
    97
    how do i setup DISA in 3CX.
    Caller calls to line connected in 3CX and gets the dialtone, then callers dials out using other line of 3CX.
    sanket
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    DISA is not supported in the manner as you have described. However, an outside call is possible from within Voice mail. An extension owner accesses their voice mail and, if enabled, can then call an external number from there. This requires an enable of the custom parameter VMDIALOUTENABLED (set to 1) in the advanced settings. This is V11.
  3. leejor
    11,291
    361
    I've done a "work around" using a PSTN line (yes, it means you have to use a PSTN line) connected to the FXO port of a SPA3102. The VoIP side is then registered to a 3CX extension, with (probably) a "somewhat restricted" set of outbound rules. The 3102 has the optin of using caller ID or PIN screening, of callers, to prevent unauthorised access.
    Of course this is limited to one call at a time, but it does a good job of simulating a DISA trunk.
  4. sanketgroup
    Jun 28, 2012
    97
    yea, u have used 3102 for DISA, but it does not provide good quality of audio.
    Hope 3CX will develop DISA in upcoming version.
    Thanx
  5. leejor
    11,291
    361
    I haven't had any problems with the audio. It is not the best solution, obviously, a true DISA port world be preferable, but, I put in a feature request two years ago http://3cx.ideascale.com/a/ideas/search?query=disa and it has yet to appear.
