Disable 3cx Phonebook
Discussion in '3CX Phone System - General' started by Steven.Zhang, Mar 16, 2018.
  1. Steven.Zhang
    Oct 16, 2017
    9
    I am using V15
    Is it possible to disable the 3cx company phonebook.
    I enabled the Do not show extension in 3CX company phonebook option but the extensions still can be found in the phonebook.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @Steven.Zhang
    I am afraid there is no way to disable the phonebook completely. Enabling the option to not show extensions in phonebook that you mentioned should work though. Make sure that you update the company phonebook on your ip phones.
    You can also post this as a feature request to our ideas section of the forum where it can be upvoted by other users and evaluated by the appropriate departments.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    756
    39
    If you use Yealink phones then go to “Directory > Remote Phone Book” and remove “Remote URL” and “Display Name”.
    The phonebook is now disabled/removed on that particular phone.
    If this is OK than you also can make changes in the template to prevent showing the phonebook.
