Disable additional lines
Discussion in 'Windows' started by generaldaze, Mar 28, 2011.
  1. generaldaze
    Mar 28, 2011
    Hey guys,
    we have just installed the 3CX softphone and it works pretty good. Is there a way to disable the additional lines? this is because if the user is on a call , and he receives another call, the line2 will start ringing and we dont want this to happen. Is there anything that I can do at softphone client configuration level?
    thanks
  2. willow
    willow Member
    Mar 1, 2011
    471
    under the extension forwarding in the 3cx system there is a check box for "I want to receive more then one call. that would need to be unchecked.
  3. generaldaze
    Mar 28, 2011
    hey mate ta for the quick answer!
    forgot to mention that we are not using the 3cx based pbx system but a Cisco Uc500 unit. We are in a evaluation phase of 3cx products.
    Is that anything we can do at client side?
    thanks
  4. willow
    willow Member
    Mar 1, 2011
    471
    you should be able to do a "huntstop channel" command on the ephone dn that does not need to ring for a second call.
  5. generaldaze
    Mar 28, 2011
    that worked great mate!
    thanks for the tip
