Disable authentication?
Discussion in '3CX Phone System - General' started by douille, Dec 18, 2007.
  1. douille
    Dec 18, 2007
    Is this possible to create extensions that require no authentication, no PIN?
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Yes it is possible. Just create the extension and fieled "Authentication->Password" leave empty.
    regards,
  3. douille
    Dec 18, 2007
    I tried this, but it doesn't work...
    The system require an authentication (with a blank password, but an authentication)
  4. alicic
    alicic New Member
    Oct 3, 2007
    119
    I have created an extension in my 3cx Phone system without password and use it with X-lite Softphone without problems.
    When creating the extension try first to delete password field and then press button ok,
    regards,
  5. douille
    Dec 18, 2007
    I receive this message: "Status-Line: SIP/2.0 407 Proxy Authentication Required" In my protocol analyzer...
  6. douille
    Dec 18, 2007
  7. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Yes, it has been done intendedly to increase system's security. What's wrong in it?
