Disable auto-start
Discussion in 'Windows' started by fonewiz, Jul 23, 2015.
  1. fonewiz
    May 13, 2015
    44
    Is there an option to set 3CX Softphone for Windows to NOT auto-start with Windows? If so, where? I don't use it normally but want to leave it installed for testing. Each time I start Windows I have to manually close the app. I have looked everywhere but can't find an option to turn off auto-start with Windows. I can disable it in the OS but I wondered if there was an easier way within the app so I don't have to walk users through disabling in the OS if they also don't want it to auto-start. Thanks
    11,079
    324
    It's been a while since I installed one, but I seem to recall that it was an option that you were offered during the install process.
    On the version I have on one computer (6.0.xxxxxx), if you click on the "button" centre bottom it will open icons, select Preferences, under Behavior (on the right) you will see a check box for Automatically start at windows logon, uncheck that.
  3. fonewiz
    May 13, 2015
    44
    It's not under behavior or anywhere else I can find. I will try uninstalling and re-installing to see if the option comes up at install time.
    Thanks.
  4. positron
    Jan 14, 2013
    76
    11
    3CX Phone is added to the legacy Windows "startup" group.
    You can delete it from the Startup group in the Programs list (Windows 7 or earlier) or directly from
    "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup"
  5. fonewiz
    May 13, 2015
    44
    I did the uninstall and re-install and I can confirm that at no point does the installer ask you if you want to auto-start the soft-phone. It seems that this checkbox under behavior existed at one point and not sure why it was removed. It makes sense that people may want to have it installed for example on a laptop that they travel with but not want to use it or hassle with it every time they boot up the laptop.
    I did remove it from the Windows startup and knew I could do that, just wondered if there was an option in the software to do the same.
    Thanks for your help.
