Disable auto-startup on 3CXPhone for Windows
Discussion in 'Ideas' started by hood, Jan 25, 2017.
Disable auto-startup on 3CXPhone for Windows 1 5 1votes
1/5, 1 vote
  1. hood
    Jun 2, 2015
    36
    It would be nice to have the option to disable auto-startup for the 3CXPhone client for Windows returned again.
    It appears this used to be a feature under preferences, but isn't there anymore.
    MSmeets likes this.
  2. MSmeets
    Sep 25, 2017
    32
    Yes , I want this option to.
    You can disable 3cx from Task Manager, tab 'startup':
    this will change this registry key:
    Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\StartupFolder
    I still looking for to disable 3CX for only current user....but cannot find it .
    (and looking for answer if you can use it on terminal server)
