Disable divert to voicemail button in client
Discussion in 'Ideas' started by rsuren, Sep 25, 2017.
Disable divert to voicemail button in client 5 5 5votes
5/5, 5 votes
  1. rsuren
    Sep 21, 2017
    34
    HI
    we have disabled voice mail for all extensions but in 3cx windows client , when a call comes next to answer button the voice mail button is there out of the 3 options given. so user by mistake clicking voicemail button and call is being lost. is there anyway to disable this in the client.
    actually being big and its being on the right hand side is the issue, our ppl are clicking it by mistake, please in future version give a command line parameter at least to disable the button.
  2. mortenjorge
    Apr 1, 2015
    58
    11
    Yes this is really a need for us, some clients use this option as a way, to ignore the calls - which is real bad... - We've disabled the voicemail, but the box is still there....
  3. Shanep
    Apr 26, 2017
    This is an issue for us too, not sure why it would be a compulsory feature for a telephony system used in contact centre environments
  4. Rhys Davies
    Nov 30, 2017
    Agree. This is an issue for us too and we run the pro call centre version. Really shouldn’t show if voicemail is turned off for the user
  5. joemiller312
    Mar 8, 2018
    This might be a strange request but we have extensions setup entirely for the purpose of being a departmental voicemail box. It'd be nice if we could customize the functionality of the divert to voicemail button to route to a specified extension's voicemail instead of just the actual user's voicemail box. Otherwise, just disabling the button would be helpful too.
