Disable DND
Discussion in '3CX Phone System - General' started by stevodevo, Mar 22, 2011.
  1. stevodevo
    Aug 17, 2010
    18
    Is there a way to disable the DND function on the phones? We have a number of our call center staff abusing the DND function and are not available for inbound calls. They are all using the 3CX softphone, so I can't just change the template.
    Does anyone have any other ideas?
    Steve
  2. willow
    willow Member
    Mar 1, 2011
    471
    change the code via 3cx dial codes. most phones you can also disable the DND feature but just remember that they are 2 different features and dont interact with each other.
