Disable DND
Discussion in '3CX Phone System - General' started by AZ-Brad, Jan 19, 2018.
  1. AZ-Brad
    Jun 29, 2017
    19
    anyone have an easy change this line on template.
    I have a client with T19p, T28p, T22p and T38G phones and they want the DND button to NOT work.
    I guess they have people putting in DND a lot and we need to stop that from happening.
    Anyone have the best solution to this? don't care if button is there, just don't want it to enable DND.
    Thanks!
    Brad
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Methinks if you go to dialcodes and remove the codes to put it in DND this will accomplish what you wish.
    vanick likes this.
