Disable external calls Dis problem
Discussion in 'CRM / Helpdesk / App Integration' started by Efe, Apr 13, 2018.
  1. Efe
    Efe
    Apr 13, 2018
    5
    i m reyting toplam create extensions in a windows form program. But when i checked tüm from web interface of 3cx i saw that all extensions created with disable external calls property checked now i try to update as unchecked disable external property but i couldnt find custom property of disable external calls could you specify me how can i change the property
  2. Efe
    Efe
    Apr 13, 2018
    5
    Sorry for my keyboard eşit
    i m trying to create extensions in a windows form program. i created them then when i checked from web interface of 3cx i saw that all extensions created with disable external calls property checked now i try to update as unchecked disable external property but i couldnt find custom property of disable external calls could you specify me how can i change the property
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,673
    131
    Please take a look at the 3CX Call Control API:
    https://www.3cx.com/docs/call-control-api/
    The Extension class has the Internal property, with the following description:
    Which seems to be what you need....
  4. Efe
    Efe
    Apr 13, 2018
    5
    i couldn't find disable extension calls property :(
    do anyone knows the property name?
  5. edossantos
    Jun 27, 2007
    1,673
    131
    You can't disable calls to internal extensions.
  6. Efe
    Efe
    Apr 13, 2018
    5
    Is there anyway to set this property from database or using remote another api ?
    Because we have 700 staffs and we need to change disable external calls property.
    This is very difficult to change property from web application as manually.
  7. edossantos
    Jun 27, 2007
    1,673
    131
    You can export extensions to csv, edit that from Excel for example, and the import extensions again.
    You have the 3CX Call Control API, but you need to execute it locally.
  8. Efe
    Efe
    Apr 13, 2018
    5
    thanks for your helps and feedback,
    Actually i would like to change disable external calls property by 3cx call control api.
    i can create extensions and change other properties by 3cx call control api.
    But i couldn't change the disable external calls property.
    I insert the screenshot image to attachment that shows the property, maybe there is a way to change the property by 3cx call control api
  9. edossantos
    Jun 27, 2007
    1,673
    131
    You need to use Extension.Internal to do that.
  10. edossantos
    Jun 27, 2007
    1,673
    131
    Extension.Internal = true >> means that the extension can't make external calls
    Extension.Internal = false >> means that the extension can make external calls
