Disable features on 3CX Softphone
Discussion in 'Windows' started by daveatgower, Jan 27, 2016.
  1. daveatgower
    Sep 21, 2015
    Is there a way to disable some of the features within the 3CX Softphone for Windows. Example from the switchboard, everyone appears to have the pulldown option for user/receptionist/manager/q-manager/wallboard. We only want the users to see the users. Yes they only have security settings as a user.
    Is there ways to disable some of the configuration settings.
    Not show Recordings, Advanced Settings, Themes, Import Contacts, etc...
    Kind of like Group policy for Windows???
    Thanks, Dave
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There
    You can limit the extension from seeing its recordings, this is done by unticking the 'Show Call Recordings' check box from the extensions settings '3CXPhone' tab within the management console. You can also hide forwarding rules.
    The other features though can not be disabled.
