Disable/hide contacts on 3CX Phone 14 for Android 5.* and above
Discussion in 'Ideas' started by JacobL, Dec 1, 2015.
  1. JacobL
    Dec 1, 2015
    I was told via Support Ticket to try these steps: For the contacts on the 3cx client this can happen on Android so go on the Settings of the Android >> Apps>> select the 3cx client >> Permissions and disable Contacts.
    Unfortunately, once Google released Lollipop, it appears that app permissions management has been removed. I now have the Company book and and my personal contacts in the apps phonebook which makes it hard to scroll through and find the correct contacts.
  2. MSmeets
    Sep 25, 2017
    32
    Thank you for this post, because I was looking for this :)
    In my Android this is working (deny permission).
    I wish / hope 3CX is adding this option inside the App in the future, instead of this silly way of deny persmission.
