Disable * in queue
Discussion in 'Ideas' started by 3wt, Jan 20, 2016.
  1. 3wt
    3wt
    Sep 15, 2008
    8
    At this moment there are 3 reasons that a call is transferred to the destination if no answer within a queue. No agents, maximum queue time and a caller hitting * key.
    What we want is a possibility to disable the feature that a caller can hit the * key to go to the destination if no answer.
  2. telin
    Jul 28, 2015
    54
    6
    It is possible to modify, or delete the prompt from the system files.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,100
    203
    deleting the prompt disables the user from hitting the "*" key?
  4. telin
    Jul 28, 2015
    54
    6
    Nope, but at least you do not advertise it. Just a temp solution for the op.
    Obviously, disabling the * is something that needs to be done, had those issues myself.
