Disable Line
Discussion in '3CX Phone System - General' started by Bob, Aug 6, 2007.
  1. Bob
    Bob
    Aug 1, 2007
    39
    How can I disable a outgoing line?
    I share my VoIP account with two machines and it can only be active on one. Is there a way to disable the line on one machine without deleting the entry?
  2. gbarnes
    Aug 3, 2007
    83
    I think you could use the backup outgoing line settings, then select the line to not use, eg manage line, then select DO NOT REGISTER.
    Then it would fail over to the next provider?
    I think thats what you mean, but correct me if im wrong! :shock:
    Graeme.
  3. Bob
    Bob
    Aug 1, 2007
    39
    Oh, I'm such a dope!
    It turns out the same VoIP Buster account configured on two 3CX servers will allow two simulatious calls on the same account.
    I forgot to dial "9" to get an outside line on one of my SIP phones. duh!
    e.g. I no longer have a reason to disable VoIP Buster on one of my 3CX servers.
    Thanks the same!
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Bob,
    At "Outbound Rules"=>"Manage"=> "Edit Outbound Call Rule"=>"Apply this rule to"=>"Calls from extension(s)", you can define which extension(s) to use that VoIP Provider.
    Regards,
    5Q
