Disable LLDP option in Provisioning tab
Discussion in 'Ideas' started by VictorSP, Sep 12, 2017.
Disable LLDP option in Provisioning tab 5 5 3votes
5/5, 3 votes
  1. VictorSP
    Sep 6, 2016
    65
    12
    Hi team,
    Thanks for adding VLAN management on the Provisioning tab for example when using Yealink phones, it makes deployments easy. The problem is that LLDP is enabled by default in the default template so we need to use a custom template disabling it, or manually per phone.
    Is it possible you also add the option of disable LLDP in the provisioning tab, please?
    Thanks!
  2. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
  3. Silly English Kniggit
    Sep 13, 2017
    220
    85
    What have you got against LLDP?
  4. VictorSP
    Sep 6, 2016
    65
    12
    Hi Silly,
    I'm not againts LLDP but in customers where we don't control the LAN settings it usually causes a big headache.
