Disable pickup call from a specific extension
Zacharias
Is is possible to disable pickup call from a specific extension? We would to have pickup function but to be disable from someone to pickup a call from reception.
Thank you in advance
Zacharias
Hello @Zacharias
The only way i can think of that this can be achieved is to place the reception extension to a different extension group and enable the option "Limit Call Pickup to calls received in their extension group" under Settings / PBX.
This way the extensions will not be able to pick up reception calls but can still pick up other calls. This would mean however that the reception cannot pick up calls from other extensions as well.
Reactions: Zacharias
@YiannisH_3CX That will do the trick.
Thank you for the fast response.
Glad i could help :)
Getting Started - Admin
Steffen Ekerdt
Get 3CX - Absolutely Free!
3CX
