Disable Proxy mode.
Discussion in '3CX Phone System - General' started by wzaatar, Sep 23, 2008.
  1. wzaatar
    Aug 1, 2007
    90
    Hello, everyone...
    I've got a tough question here: :shock:
    Scenario:
    I have two LANs (192.168.1.0/24 and 192.168.2.0/24), each with one SIP ATA (192.168.x.5), in addition I have installed a 3CX server on 192.168.1.1
    Configured everything without STUN, extensions (101 for 192.168.1.5 and 201 for 192.168.2.5) call each other without any problem.
    Now... My issue:
    I have recently acquired a DID number and set it to ring on ext. 101, everything works fine, audio is still crystal clear... However, when I set it to ring on ext. 201, audio is garbled: the reason, as I discovered it when logging verbose: the 3CX server sits as a 'proxy' and forwards RTP packets from 201 to the external DID and vice-versa...
    So RTP packets going to 201 are going through the SIP server and are being relayed to the extension despite the fact that I disabled PBX audio relay in 3CX.
    The link between the two subnets cannot handle extra bandwidth need.
    Does anyone have any solution for this?
    And thanks!
    w.
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Even if you have disabled PBX delivers audio for both devices, you must have Supports Re-Invite enabled for both of them.
    If this is disabled, the PBX will still deliver audio.
    regards
  3. wzaatar
    Aug 1, 2007
    90
    Hi Alex,
    Thanks for the reply!
    Both the DID/DO and the extension are configured to support re-invite and 'replaces'... Yet it doesn't fix it! :cry:
    3cxMedia snapshot:
    You can see from the above that internal calls are in "by pass" mode whereas DID calls are "proxy mode"
    Thanks!
    W.
