Disable Queue Logout
Discussion in '3CX Phone System - General' started by Manoj Perera, Aug 8, 2017.
  1. Manoj Perera
    Aug 8, 2017
    6
    9
    Is it possible to disable queue toggle (login/logout) of 3CX phone client as an admin privileged option? So user cannot change or logout from queue without supervisor/admin permissions.
    Queue login/logout should automatically trigger when user change the status.(ex: Ready, Away etc)
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @Manoj Perera
    Please note that this is not possible but you can submit it as a feature request on our ideas section of the forum where it can be upvoted by other users and evaluated by the appropriate department.
