Disable Recording Rights
Discussion in '3CX Phone System - General' started by neville, Jul 24, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    222
    39
    Maybe I am missing something but I cannot find how to disable recordings for an extension. Can someone please enlighten me.
    Chuck
  2. Taff3333
    Jan 18, 2017
    21
    6
    Recording for all users is disabled by default.
    - If you tick the option to record all calls, it will record all calls for that extension.
    - If you leave it unticked, it will not record anything.
    Normal users cannot enable recording for their extensions. Only the Administrator should have access to the 3CX PBX, this means that only the administrator can enable recording for each extension.
    This wont stop manual recordings though
  3. neville
    neville New Member
    Apr 23, 2012
    222
    39
    I do not have the option ticked but the call can still be recorded from the windows client. I cannot access the recording, but it is recorded.
    Chuck
  4. Taff3333
    Jan 18, 2017
    21
    6
    Thats what i meant by manual recording, you cannot stop the user recording but you can stop them accessing the recordings.
    Under extension - Phone provisioning - change to IP chone (drop down) - Untick Show call recordings and Allow deletions
    Also you can make sure under rights, Allow downloads of call recordings is unticked if user has PBX console access
    teldata1 likes this.
  5. neville
    neville New Member
    Apr 23, 2012
    222
    39
    Thanks Taff3333.
  6. Taff3333
    Jan 18, 2017
    21
    6
    Glad to help
    GiannosC_3CX likes this.
