Disable Recording
Discussion in 'Windows' started by insightbill, Jul 9, 2014.
  1. insightbill
    Jul 9, 2014
    Many of our clients are law enforcement. While they like the integration with outlook, they remind us the illegality in the USA to record conversations without a warrant or consent (illegal wiretapping). Can we please have a way to use the this feature but disable the Recording ability on the 3cX Myphone? Otherwise we will have to limit deployment of part of a product.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Unfortunately 3CXPhone recording recording feature cannot be disabled, but what you could do is using a queue with option "Give caller ability to opt out of recording (DTMF 3)". Then have in your intro prompt the info stating if one presses 3 call will not be recorded.
