Disable recording
Discussion in 'Ideas' started by andrea.soc, Feb 26, 2016.
Disable recording 5 5 9votes
5/5, 9 votes
  1. andrea.soc
    Feb 24, 2016
    39
    7
    Add the ability to disable recording call from client , from management.
  2. andrea.soc
    Feb 24, 2016
    39
    7
    c'mon guys ! this is very important for the privacy
  3. Patrick B
    Jan 11, 2017
    This is also immensely important for us!
  4. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    I also requested this one for years. My workaround on Windows was quota restrict the recording directories.
    End-users still have the button and it looks like it is recording but the files never actually write.
  5. cel
    cel
    Jul 15, 2015
    34
    23
    I think this is a very important feature that should available in the clients (Mobile and Windows). It would be good if we could activate/disable it within the management console for a particular user.
    Patrick B likes this.
  6. Patrick B
    Jan 11, 2017
    Permissions on the fileshare or what you mean exactly?
  7. cel
    cel
    Jul 15, 2015
    34
    23
    I think what he means that he forbid to the 3CX service user to write into the recordings directory on the server.
