Disable sip trunk
Discussion in 'Ideas' started by marnet, May 5, 2016.
Disable sip trunk 4.9 5 32votes
4.9/5, 32 votes
  1. marnet
    Sep 9, 2009
    I think it might be useful to add a button to disable or enable a sip trunk without having to delete.
    Regards
    Eurylink, rayfield and jlinds like this.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Agreed. There is disable all and enable all but not any way to specifically disable one sip trunk. Would be helpful in some instances.
  3. JCarnes
    Apr 25, 2016
    21
    Agreed. This would be very helpful, and it is something that is a feature of the FreePBX systems we are trying to migrate over to 3CX from.
    jlinds likes this.
  4. rayfield
    rayfield New Member
    May 4, 2010
    126
    I just needed this capability just last week.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Edit the trunk you want then options and de-select Allow Inbound and allow outbound calls. In authentication based trunks will will un-register the trunk as well
    Dave-TTG likes this.
  6. rayfield
    rayfield New Member
    May 4, 2010
    126
    Very creative solution. Excellent! Thanks.
    John
  7. marcolagoa
    Oct 27, 2015
    7
    We need it!
  8. cschmaus
    May 22, 2017
    Very good idea!!!
  9. techdummy
    techdummy New Member
    Sep 22, 2017
    182
    9
    This would have been big help as we are doing a testing on a Demo version with the backup from the live version, which includes all the trunk details too.
  10. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    I think that Disable all button should be renamed to Disable selected trunks like it is possible to select multiple services to restart?
    craigreilly likes this.
  11. infoway
    Oct 23, 2012
    5
    +1 for this request.
    I'd like a way to disable a single trunk without have to edit properties.
    By the way i'd like to enable/disable a specific voip trunk via API too.
  12. rousseaux
    Apr 11, 2017
    +1 a button to desable one or two or only selected trunk is a good Idea
