Disable some system messages
Discussion in '3CX Phone System - General' started by patroclo, Sep 4, 2012.
  1. patroclo
    Jan 22, 2011
    9
    Is it possible to disable some of the system messages ?
    I configured an ivr, the caller has to press a number on his phone to automatic transfer the call to the right extension, then the message "pls hold on..." plays, I would like to avoid the message plays
    thank you
  2. mirjam.nz
    Dec 6, 2010
    28
    Hi Patroclo
    To get rid of this message you have to re-recorded / replace the System Prompt "please_hold.wav" with a silent wave file. Once done, restart the services. According to 3CX Support, this is the only way to disable this "feature".
    Cheers
    Miriam
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Or you can even use default empty.wav from 3cx (dont need to record the new one :D )
