Disable Switchboard through permissions
Discussion in 'Ideas' started by TSlocum, Oct 4, 2016.
Disable Switchboard through permissions 5 5 4votes
5/5, 4 votes
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    There should be a permissions option to entirely disable the switchboard in the desktop client. Currently, extensions who are logged in to queues can view who is logged in and out, as well as phone numbers agents are connected to.
    This information should be available to managers only, if desired.
    rayfield likes this.
  2. digiteo
    Mar 22, 2016
    17
