Disable TLS1.0 on 15.5
Discussion in '3CX Phone System - General' started by asmith3006, Feb 16, 2018.
  1. asmith3006
    Mar 5, 2014
    94
    5
    Is it safe to disable TLS1.0 on 15.5? I've found a few posts talking about much older version and the issues it's caused, but I couldn't see anything regarding the newer versions.
  2. keithshook
    Jul 25, 2010
    8
    Latest update 1.5.5 sp3 still failing PCI scan :( was hoping it was fixed :(
