disable web console?
Discussion in '3CX Phone System - General' started by joemailey, Sep 26, 2017.
  1. joemailey
    Jan 3, 2014
    25
    Hi Folks,
    I was wondering if its possible to disable the web console from outside of the lan?
    at the minute I can hit port 5001 and access the web console from anywhere and I'd like it to only be available inside my internal network. I think port 5001 is used for presence info and provisioning so kinda need that side of it to still work.
    Thanks,
    Joe
  2. Archie Frederic
    Jan 31, 2017
    72
    As far as I know, it is possible. But not through 3cx itself. You could disable it through removing the port forwarding of https and http port you had used during the initial installation of 3cx.
