Disabled PBX deliver audio but it does not seems to working properly.
Discussion in '3CX Phone System - General' started by aslam, Jun 22, 2016.
  1. aslam
    May 22, 2016
    32
    Disabled PBX deliver audio in 3cx (both gateway and Ext) but it doesn't seems to be working with Grand stream PSTN gateway. When I make ext to ext, audio delivers IP to IP but when I make external calls, audio still delivers from 3CX server. What could be the reason?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    Re-invites?
  3. aslam
    May 22, 2016
    32
    How to re invite?
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    In the GW Settings in the Management Console, above the "PBX Delivers Audio" option. Personally I recommend having "PBX Delivers audio" enabled for GWs and options "Support Re-Invite" and "Support Replace" disabled.
    Also note that if an extension makes a call out through a GW, even if only 1 of the 2 has "PBX Delivers Audio" enabled, the audio will still be proxy'd though the 3CX Server.
