way
Platinum Partner
- Joined
- Feb 21, 2011
- Messages
- 48
- Reaction score
- 4
Hello
The 3cxphone app has been working pretty well, but we currently cannot figure out how to disable that popup that appears in the bottom right-hand corner of the pc when a call comes in. This popup goes over the top of all the running applications and can disrupt the workflow of the employees. We only use the 3cxphone for its presence information and the ability to drag and drop to transfer calls.
Is there a way of disabling this feature while still being able to accept calls on the phone?
