Disabling Intercom feature
Discussion in '3CX Phone System - General' started by dcsymonds, Oct 10, 2012.
  1. dcsymonds
    Oct 10, 2012
    7
    Is there any way of disabling the intercom feature? We are looking to use 3CX in our organisation, but having intercom enabled is a showstopper.
    The nature of the company means that we can't have people able to just open a line to somebody.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    I assume you mean the intercom feature that is, by default (paging), invoked by using "*9". If so, go to settings, advanced, and then dial codes and change the "*9" code to something else that no one else will know and is more difficult to guess. .
  3. dcsymonds
    Oct 10, 2012
    7
    Yes that's what I'm talking about, but you can also invoke it from myPhone, would changing the *9 extension disable this?
  4. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    if you put somethink else (e.g.*97) it will still work via myphone
  5. dcsymonds
    Oct 10, 2012
    7
    We tested it but we want to disable it completely
  6. lneblett
    Sep 7, 2010
    2,061
    56
    You might also simply try erasing the entry so that the field is blank and try.
  7. dcsymonds
    Oct 10, 2012
    7
    Unfortunately you can't have it blank.
  8. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    try this,
    go to advanced, customer paramaters, find INTERCOMM and delete *9 (leave the field empty). then apply ok, restart service and try
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    I think there is a request in the facebook ideas page.
    We for now at least have intercom mute enabled by default.
    Users of course might turn this off in the phone - but it was a good work around for us.
  10. dcsymonds
    Oct 10, 2012
    7
    Removing the intercom code worked a treat! :D Thank you!
  11. craigreilly
    Feb 1, 2012
    2,978
    183
    However, if you use a Ring Group for Paging, and are not using multicast, then this feature will no longer work.
  12. netswork
    netswork Active Member
    Mar 11, 2011
    577
    What phone did you set the mute option on?
  13. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Depending on the phones that you are using, you can modify the template to NOT allow auto answer. This solves the intercom issue but will likely kill the ability to initiate calls via myphone or Outlook.
    Charles
  14. craigreilly
    Feb 1, 2012
    2,978
    183
    Some phones have ability to dial by URL so phone initiates call instead of server.
    Or...
    some with "mute on" 3cx will still call the phone but will be muted.
