disabling SIP ALG on EdgeRouter
Discussion in '3CX Phone System - General' started by choksw, Oct 28, 2016.
  1. choksw
    Oct 24, 2016
    6
    Hi All,
    I have seen many posts online regarding disabling of SIP ALG on routers. Strange thing is, after I have disable SIP on my EdgeRouter, the remote IP-phones failed to connect to 3CX PBX.
    Any ideas why? Thanks!
    11,073
    323
  3. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    What problems were you having before you disabled SIP ALG? How are your ports forwarded for your 3CX server? Are you doing 1 to 1 NAT, sounds like maybe ports are being changed by the router. Could be a lot of things, what are you seeing in logs on the edgerouter? Are you using Unifi phones as well that are managed through the unifi software?
