disabling some services?
Discussion in '3CX Phone System - General' started by tfit, Apr 15, 2008.
  1. tfit
    Apr 15, 2008
    Morning good people,
    Can someone tell me which services I can safely disable. I just download v5.1 and everything looks good, but I see services I don't need. Before I open pandora's box I like to know which services I can disable.
    Thanks in advance.
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    You can safely disable the FAX service and TUNNEL service.
  3. tfit
    Apr 15, 2008
    Dankjewel Matthijs,
    I noticed you can also disable the management console (apache). I have another instance of apache running and I accidently stopped the wrong one. The pbx still works without only problem.
