Disallow extensions to be reached by the Digital Receptionist
Discussion in 'Ideas' started by josea, Nov 17, 2017.
Disallow extensions to be reached by the Digital Receptionist 4.8 5 4votes
4.8/5, 4 votes
  1. josea
    Sep 13, 2017
    23
    6
    We would like to be able to flag some extensions as "not reachable by Digital Receptionist".
    This is for extensions that have DIDs assigned to them.
    If an extension is flagged as not reachbled by Digital Receptionist, and the caller dials that extension number, either the call should end, or the Digital Receptionist should say "Invalid Extension" or similar.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    YES!
  3. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    I would add, select option on what to do with call from IVR: Busy, VM, other extension, etc - Just like forwarding rules.
  4. jeroendebruijn
    Nov 9, 2015
    35
    18
    Rater make it an option for each Digital Receptionist.
    I have several companies where, if we call form a certain CID, our call get redirected to a Digital Receptionist, so we are able to call an extension directly. Great for trouble shooting, and skipping long queues :) But meanwhile, there is also a Direct Receptionist asking what department a caller wants to connect too. I would prefer the later not being able to enter an extension number.
