Disconnect Call after x minutes
Discussion in 'Call Flow Designer' started by ibrahim akgün, Feb 26, 2018.
  1. ibrahim akgün
    Feb 26, 2018
    29
    Hi guys,
    Any idea how to track call times (inbound or outbound) and then disconnect call after x minutes?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,355
    108
    Hello @ibrahim akgün,
    You need to control calls between 2 endpoints, and none of them is a CFD app (for example an internal extension and an external number), so you can't use the CFD for this.
    You can create a C# program using the 3CX Call Control API, subscribe to events to know when a call starts and ends, and then you can disconnect any call after X minutes.
    Kind regards.
