DISCONNECTED AFTER 30 SECONDS !
Discussion in '3CX Phone System - General' started by iainaa, Oct 25, 2007.
  1. iainaa
    Oct 23, 2007
    21
    After much playing about with config files, ring groups and office hours ive finally got 3cx to work with patton 4114 gateway HOWEVER incoming + outgoing calls only last 30 seconds brfore it hangs up itself . Can anyone please help me urgently, i was meant to install this on Monday.
    Thanks In advance
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Try to disable second NIC card on PC running 3CX SIP Server. This is how I solved my problem with call disconect,
    Hope it helps,
  3. chriscasas
    Nov 1, 2007
    I had the same problem before.
    I re-installed 3CX and it worked well.
