GMBİL
- Joined
- Jun 4, 2009
- Messages
- 9
- Reaction score
- 0
I'm using Vega 50 Europa 4FXO with 3CX latest version, i can manage to dial out but after 5-10 second the call looses audio, it seems still connected on both external and internal side but no audio...
Any ideas?
Below 3cx Logs,
10:34:26.763 [CM503008]: Call(78): Call is terminated
10:34:26.757 [CM503008]: Call(78): Call is terminated
10:33:51.026 Session 15113 of leg C:78.1 is confirmed
10:33:50.935 [CM503007]: Call(78): Device joined: sip:[email protected]:5060
10:33:50.920 [CM503007]: Call(78): Device joined: sip:[email protected]:5060
10:33:50.919 [CM503021]: Call(78): Call recording is started, audio file: C:\ProgramData\3CX\Data\Recordings\101\[Mehmet Ali Demirci]_101-905544021790_20090606103350(78).wav
10:33:50.915 [MS210003] C:78.1:Answer provided. Connection(transcoding mode):192.168.0.100:7354(7355)
10:33:50.914 [MS210001] C:78.2:Answer received. RTP connection: 192.168.0.110:10002(10003)
10:33:50.908 Remote SDP is set for legC:78.2
10:33:50.907 [CM505002]: Gateway:[VegaStream_50_4FXO] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VEGAEURO/13.02.08.6xS008] Transport: [sip:192.168.0.100:5060]
10:33:50.907 [CM503002]: Call(78): Alerting sip:[email protected]:5060
10:33:47.548 [CM503024]: Call(78): Calling PSTNline:05544021790@(Ln.10000@VegaStream_50_4FXO)@[Dev:sip:[email protected]:5060]
10:33:47.546 [MS210002] C:78.2:Offer provided. Connection(transcoding mode): 192.168.0.100:7356(7357)
10:33:47.537 [CM503004]: Call(78): Route 1: PSTNline:05544021790@(Ln.10000@VegaStream_50_4FXO)@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060]
10:33:47.525 [MS210000] C:78.1:Offer received. RTP connection: 192.168.0.111:16406(16407)
10:33:47.524 [CM503010]: Making route(s) to <sip:[email protected]>
10:33:47.519 Remote SDP is set for legC:78.1
10:33:47.517 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sipura/SPA921-4.1.10(b)] Transport: [sip:192.168.0.100:5060]
10:33:47.504 [CM503001]: Call(78): Incoming call from Ext.101 to <sip:[email protected]>
10:33:47.496 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.0.111:5060;branch=z9hG4bK-a3cb6cac
Max-Forwards: 70
Contact: "Mehmet Ali Demirci"<sip:[email protected]:5060>
To: <sip:[email protected]>
From: "Mehmet Ali Demirci"<sip:[email protected]>;tag=b13731bc44217b2o0
Call-ID: [email protected]
CSeq: 102 INVITE
Expires: 240
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Proxy-Authorization: Digest username="101",realm="3CXPhoneSystem",nonce="414d535c003aacdb79:bf9e7f12c5a0d2443fa9af4bd5276313",uri="sip:[email protected]",algorithm=MD5,response="eb34a45c4b6661e13fb9c31b112df60b"
User-Agent: Sipura/SPA921-4.1.10(b)
Content-Length: 0
Any ideas?
Below 3cx Logs,
Max-Forwards: 70
CSeq: 102 INVITE
Expires: 240
Content-Length: 0
