Display group in Assistant
Discussion in '3CX Phone System - General' started by muaddib32, Nov 24, 2010.
  1. muaddib32
    Oct 16, 2010
    68
    I have set up call groups and configured it so that the group name is prepended to the CID. This is fine and works well on the phone display. Is there anyway to configure this to show up in the Assistant alert? At present it justs shows the incoming phone number. I would prefer if staff didn't have to peer across at the handset display if possible.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, this was added in the features list for next version.
  3. muaddib32
    Oct 16, 2010
    68
    Ok. Great.
  4. chalks
    Mar 25, 2010
    Hi!
    Am wanting the same feature as well. Has this already been released?
    Thanks.
