Display incoming called number
Discussion in '3CX Phone System - General' started by wiggum123, Jun 14, 2017.
  1. wiggum123
    Apr 7, 2014
    5
    Not sure if this has been covered before, I have tried to search so sorry if this is a Repost.
    I am trying to display the number dialed by an incoming caller. We have a load of different external numbers assigned and want to display how the caller got through. If it is possible to replace the number with text or have a different ring specific to the number dialed that would be even better
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @wiggum123
    I would assume that you have DID's assigned to the system. If that is the case then you will need to create an inbound rule for each of the DID's.
    Each inbound rule can be named with a distinctive name or even with the number of the DID.
    You will then navigate to contacts / options and enable the option "Add Group, Queue or DID/DDI Names to Caller ID"
    Now when a caller rings a specific number and the system follows that inbound rule to forward the call then the name of the inbound rule will appear on the screen of the phone.
