Display more columns in Extensions oder Phone Overview List
Discussion in 'Ideas' started by ck1_hh, Dec 1, 2016.
  1. ck1_hh
    Jun 11, 2010
    10
    5
    it would be great if you could display more columns in the overview Page.
    Like MAC Adress in Extensions-List or Forwarding Rules (with Settings), Restrictions, Options and Rights.
    Maybe it would be great that you can individually set the columns and save the settings or at least select them...
    Thanxs
    Carsten
    KJM_Complea likes this.
