Display Ring Group (what option was selected) on phone
Discussion in '3CX Phone System - General' started by rhys100, Apr 7, 2017.
  1. rhys100
    Apr 7, 2017
    24
    Im using Yealink Phones and running two businesses.
    We have one number incoming.
    Customers select 1 for business one
    customers select 2 for business two.
    Is there a way on the phone the person who picks up can see if they selected business one or two?
    Currently using ring groups, but it doesnt show on the phone what ring group they selected.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @rhys100
    Assuming you are running V15 you can navigate to contacts and under options select Prepend Name under the Add Group, Queue or DID/DDI Names to Caller ID
    This should prepend the name of the Ring group in front of the callers number
  3. rhys100
    Apr 7, 2017
    24
    Hi, I did this and it works for the softphone, but it does not show on my phyiscal phones.
    I am using Yealink T48G and T46g
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Are you testing this from a phone number that is present in the directory?
    If so, the Yealink phone is looking this number up and putting in the name from it's directory.
    This is done after 3cx Prepends the Group Name.
  5. rhys100
    Apr 7, 2017
    24
    Yes you are correct, was calling from my mobile. Seems you are right, if contact is in address book just says the name. Cheers
