Displayfusion's "Toggle Window Always on Top" doesn't hold for 3CX when making or transferring a cal
Discussion in 'Windows' started by datalore, Apr 11, 2016.
  1. datalore
    Jun 26, 2012
    A niggly little issue.
    I set Shift+Z in DisplayFusion Settings - Functions - Window Management - "Toggle Window Always on Top", and apply this setting.
    I open 3CX (http://downloads.3cx.com/downloads/3CXP ... dows14.msi) and press Shift+Z and the window stays on top off all other windows.
    However, after I dial a number and when I press the "call" button, the setting to stay on top is lost, and I need to reapply it. the same goes for the "transfer" button (same location in the app, and comes up when I pick up a call and need to transfer it to someone else).
    Note that dialing a number does not affect this setting - it seems only on "call", "transfer", "end call" - basically any button located at the bottom of the app.
    Wondering if you had any thoughts or if this could be fixed?
    Regards,
    Stephen
  2. datalore
    Jun 26, 2012
  3. datalore
    Jun 26, 2012
    Response from Displayfusion last week:
    So, is 3CX modifying some "topmost property" when the buttons on the bottom of the app are pressed?
  4. datalore
    Jun 26, 2012
    Just "bumping" this again to see if anyone at 3CX can suggest a solution?
