Distinctive Ring
Discussion in '3CX Phone System - General' started by dyntech, Jun 17, 2007.
  1. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Anybody using an ATA that supports distinctive ring? I would like to still be able to receive faxes but use a separate ring pattern for the fax number. I want the ATA to disregard the second ring pattern so that my fax will answer it.
  2. Anonymous
    Anonymous Guest
    Yep the SPA 3000 and 3102 will do that, with a bit of fiddle.
    What you look for is called DUET or as you mentioned distinctive ring. It is different per country (it is regional based).
  3. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Once again Henk, you are the man!
    I will let you know if I need any more help once I get one.
    Thanks.
