Distinctive Ring
Discussion in 'Ideas' started by cbroessel, Mar 20, 2017.
Distinctive Ring 5 5 8votes
5/5, 8 votes
  1. cbroessel
    May 9, 2013
    6
    Either on the sip trunks or ring groups, or both
    Bob Denny and GtInNoVaTiOn like this.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    that's really not specific as a problem...
    if properly configured, there are already distinctive rings for internal / external calls/ ring groups and queues, and more ...
    So question is : What do you want, SPECIFICALLY. What phones are you using ? Are they auto provisioned ?
  3. RedErikson
    Feb 8, 2017
    Hi JasonNadeau. I contacted tech support about this issue and they told me that distinctive rings are not an option. Can you show me where/how you configured your internal / external calls/ Ring groups and queues to have distinctive rings? I would really appreciate it as this has been bugging me for a long time.
    Thanks!
    #3 RedErikson, Mar 23, 2017
  4. jem1
    Aug 29, 2012
    81
    33
    3CX sends alert info for queue, external and internal and that's it. They rejected the idea of custom alert info headers for some reason which would make distinctive ringing so much easier.
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    47
    same question RedErikson, What phones are you using ? Are they auto provisioned ?
  6. gorbros
    Jun 8, 2015
    16
    9
    Hi, I am using 3CX V15 and have Cisco SPA504G phones provisioned. Please can you give me some guidance getting distinctive ring for internal and external calls
    Regards
    mcs4 likes this.
  7. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    This Feature has been requested already ( i think even a couple of times)
    But i still give it a +1, since i also miss it.
    We are only using the 3CX softclients btw, so there is no way do to it "via our phones" :)
    Bob Denny likes this.
  8. two
    two
    Jun 25, 2015
    16
    7
    Yealink has the options in the phone setting but to stay under 3CX Support default templates rewrite the phone to default ringrones that clients absolutely despise. Either they need to start supporting custom templates or begin matching more to the phone settings for individual client preferences.
    Totally agree on settings on 3CX for internal, external, and que ring tones!
    GtInNoVaTiOn likes this.
  9. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    Also would like distinctive ring via the DID. This would allow easy recognition of incoming calls for different purposes, which we have mapped to separate inbound phone numbers.
  10. Silly English Kniggit
    Sep 13, 2017
    220
    90
    Out of the "box" 3CX doesn't support distinctive ring - in fact in some places such as phone templates it actively disables it. It can be made to work, but it's clunky and usually requires template hacking.
    It should just support it by default. It's embarrassing that the 20+ year old analogue systems we're trying to sell 3CX as a replacement for can do this, but 3CX can't. It's a really basic thing.
    contoured and 1tb like this.
  11. Lev
    Lev New Member
    Sep 19, 2015
    127
    20
    cannot be pushed up enough... ^^
  12. Jim Canfield
    Nov 16, 2017
    13
  13. paulcaudill
    Oct 17, 2017
    19
  14. contoured
    Sep 7, 2016
    54
    5
