Divert to external number
Discussion in '3CX Phone System - General' started by Wanderer, Nov 9, 2010.
  1. Wanderer
    Nov 9, 2010
    19
    I am running the latest ver 9 with SP3, I have setup the following
    20 Extensions
    1 PSTN Gateway Linksys SPA 3102
    2 SIP providers SIPGate
    Ring Group A
    Ring Group B
    Setup Office hours
    Object to achieve is,
    1\ when a call comes in on the PSTN during office hours, it goes to ring group A
    2\ when a call comes in on the PSTN out of office hours, it goes to ring group B
    3\ out of hours, if ring group B does not answer within 10 secs the call is diverted to an external number
    If I ring an extension in group A out of office hours the complete process works fine
    If I ring from an external number the call is diverted to ring group B okay, but after 10 secs you receive a message call cannot be answered and will end, therefore not be diverted to the stated external number.
    All calls made outbound are via VoIP provider.
    Any thoughts would be gratefully received.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, from what you have explained, it would appear you are doing the call transfer via extension level and not group level.
    Goto >> Ring Groups > and set the “Forward to Outside Number” on “Destination if no answer” for Group B
  3. Wanderer
    Nov 9, 2010
    19
    Hi Dave
    Thanks for your input, the extensions forward to the Ring Group, and the Ring Group forwards to the external number, so I think this is how you are suggesting it needs to be be.
    I can not figure this one out
    Tim
  4. davidbenwell
    Apr 27, 2010
    704
    Hi Tim
    Doing what you are describing would caules a loop within 3CX
    its not the best option to use an extension to divert to a ring group, as this will caules the phones to ring again and not divert to the external number.
    what you could do is setup a dummy extension which is always set to Out Of Office and input the external number to that dummy extension. you could then tell all other extension when for example, Busy, out side of office hours, to call the dummy extension of which in turn will call the external number.
  5. teh_spartan
    Sep 3, 2010
    25
    I am trying to do something similar. I am going to write it as if then statements because I think it is easy to understand
    Code:
    if Extention 101 is not registered then forward the call to external number.
    if i don't pick up in x number of seconds end the call forwarding and send call to voice mail of extension 101.
    right now i just use office hours and when out side of office hours i the call is fowarded to my cell phone.
  6. Wanderer
    Nov 9, 2010
    19
    Hi Dave
    Thanks for your help
    Okay, I think I can see where you are coming from, so
    I have removed all forwarding rules from the extensions
    I have applied forwarding rules to PSTN adapter to forward to ring group A during office hours and to forward to ring group B
    out of office hours
    If ring group B does not answer it should forward to external number
    As I understand it this should work, can you see any problems with this. All forwarding rules are applied to the PSTN adapter and to the ring groups respectively.
    Tim
  7. davidbenwell
    Apr 27, 2010
    704
    yes this should work fine.
  8. Wanderer
    Nov 9, 2010
    19
    Hi Dave
    This config does not work either, out of hours the call still does not get transfered to the external number.
    I am really struggling with this now.
    Here is an example from my log.
    17:39:35.015 Currently active calls [none]
    17:39:26.014 [CM503008]: Call(15): Call is terminated
    17:39:20.913 Session 12262 of leg C:15.1 is confirmed
    17:39:20.898 [CM503003]: Call(15): Call to sip:28@10.25.50.6 has failed; Cause: 487 Request Cancelled; from IP:10.25.50.159:50610
    17:39:20.882 [CM503003]: Call(15): Call to sip:24@10.25.50.6 has failed; Cause: 487 Request Cancelled; from IP:10.25.50.157:50170
    17:39:20.866 [CM503007]: Call(15): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=cc72b74844a7f7f3
    17:39:20.866 [CM503007]: Call(15): Device joined: sip:70000@10.25.50.149:5062
    17:39:20.866 [MS210005] C:15.1:Answer provided. Connection(proxy mode):10.25.50.6:7048(7049)
    17:39:20.851 [MS210001] C:15.5:Answer received. RTP connection[unsecure]: 127.0.0.1:40618(40619)
    17:39:20.851 Remote SDP is set for legC:15.5
    17:39:20.851 [CM503002]: Call(15): Alerting sip:EndCall@127.0.0.1:40600;rinstance=cc72b74844a7f7f3
    17:39:20.788 [CM503003]: Call(15): Call to sip:22@10.25.50.6 has failed; Cause: 487 Request Cancelled; from IP:10.25.50.156:50510
    17:39:20.726 [CM503025]: Call(15): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=cc72b74844a7f7f3]
    17:39:20.726 [MS210004] C:15.5:Offer provided. Connection(proxy mode): 127.0.0.1:7056(7057)
    17:39:20.695 [CM503016]: Call(15): Attempt to reach <sip:82@10.25.50.6:5060> failed. Reason: No Answer
    17:39:05.922 [CM505001]: Ext.28: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] PBX contact: [sip:28@10.25.50.6:5060]
    17:39:05.922 [CM503002]: Call(15): Alerting sip:28@10.25.50.159:5060;user=phone;transport=udp
    17:39:05.906 [CM505001]: Ext.24: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] PBX contact: [sip:24@10.25.50.6:5060]
    17:39:05.906 [CM503002]: Call(15): Alerting sip:24@10.25.50.157:5060;user=phone;transport=udp
    17:39:05.890 [CM505001]: Ext.22: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] PBX contact: [sip:22@10.25.50.6:5060]
    17:39:05.890 [CM503002]: Call(15): Alerting sip:22@10.25.50.156:5060;user=phone;transport=udp
    17:39:05.594 [CM503025]: Call(15): Calling RingAll82:22Ext.2224Ext.2428Ext.28@[Dev:sip:28@10.25.50.159:5060;user=phone;transport=udp]
    17:39:05.594 [MS210006] C:15.4:Offer provided. Connection(by pass mode): 10.25.50.149:16466(16467)
    17:39:05.578 [CM503025]: Call(15): Calling RingAll82:22Ext.2224Ext.2428Ext.28@[Dev:sip:24@10.25.50.157:5060;user=phone;transport=udp]
    17:39:05.578 [MS210006] C:15.3:Offer provided. Connection(by pass mode): 10.25.50.149:16466(16467)
    17:39:05.547 [CM503025]: Call(15): Calling RingAll82:22Ext.2224Ext.2428Ext.28@[Dev:sip:22@10.25.50.156:5060;user=phone;transport=udp]
    17:39:05.547 [MS210006] C:15.2:Offer provided. Connection(by pass mode): 10.25.50.149:16466(16467)
    17:39:05.485 [CM503004]: Call(15): Route 1: RingAll82:22Ext.2224Ext.2428Ext.28@[Dev:sip:22@10.25.50.156:5060;user=phone;transport=udp,Dev:sip:24@10.25.50.157:5060;user=phone;transport=udp,Dev:sip:28@10.25.50.159:5060;user=phone;transport=udp]
    17:39:05.454 [CM503010]: Making route(s) to <sip:82@10.25.50.6:5060>
    17:39:05.454 [MS210000] C:15.1:Offer received. RTP connection: 10.25.50.149:16466(16467)
    17:39:05.454 Remote SDP is set for legC:15.1
    17:39:05.454 [CM505002]: Gateway:[01205 723444] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:70000@10.25.50.6:5060]
    17:39:05.438 [CM503001]: Call(15): Incoming call from 70000@(Ln.70000@01205 723444) to <sip:82@10.25.50.6:5060>
    17:39:05.438 [CM503012]: Inbound outside specific hours incl. holidays rule (unnamed) for 70000 forwards to DN:82
    17:39:05.422 Looking for inbound target: called=70000; caller=70000
    17:39:05.422 [CM500002]: Info on incoming INVITE:
    INVITE sip:70000@10.25.50.6 SIP/2.0
    Via: SIP/2.0/UDP 10.25.50.149:5062;branch=z9hG4bK-d5aa2970
    Max-Forwards: 70
    Contact: "Linksys SPA 3102"<sip:70000@10.25.50.149:5062>
    To: <sip:70000@10.25.50.6>
    From: "Linksys SPA 3102"<sip:70000@10.25.50.6>;tag=c9fc14644a321bc4o1
    Call-ID: 547178e4-97680144@10.25.50.149
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
    Proxy-Authorization: Digest username="70000",realm="3CXPhoneSystem",nonce="414d535c02ecbb3948:ca1013278a869856e20c7c59e5ed9937",uri="sip:70000@10.25.50.6",algorithm=MD5,response="28133773fa5944fe0320e2eb78cc9636"
    Supported: x-sipura, replaces
    User-Agent: Linksys/SPA3102-5.1.10(GW)
    Content-Length: 0
    Remote-Party-ID: Linksys SPA 3102 <sip:70000@10.25.50.6>;screen=yes;party=calling
    17:39:04.830 Currently active calls [none]
    Tim
  9. davidbenwell
    Apr 27, 2010
    704
    whats the max call wait time set to on the call group B?
  10. Wanderer
    Nov 9, 2010
    19
    Hi David
    Ring Group Setup
    Virtual machine number 82
    Name Control
    Ring strategy Ring all
    Ring time 15
    Ring group members 22,24 & 28
    Select destination for this call if
    the call goes unanswered External number xxxxxxxxxxx
    Tim
  11. Wanderer
    Nov 9, 2010
    19
    Thanks to all for your suggestions, I have know found the answer, it would appear that a Ring Group is treated as an extension, and therefore you need to add the Ring Group ID to an outbound rule.
    I completed this and it all works a treat.
    Tim
