DN numbers
Discussion in '3CX Phone System - General' started by Tony69, Oct 10, 2017.
  1. Tony69
    Jun 23, 2017
    I like use 2 digit extension numbers on my system. It's practical for me.
    But the system doesn't allow some numbers:
    77, 81
    When I try use this numbers the system show "Given DN number cannot be used".
    Possible modify the DN numbers? And if yes how to? I was search but don't found.
    Thank you
    Tony
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    Officially not. Some of hem can be changed in 'System extensions' in the Dashboard or in corresponding menu (like Digital Receptionist,, Queues, Ring Groups). To change No. 77 probably the only way is to edit the backup file -- change it to something else free like 07 or other number, and then restore the backup. Be careful, as this may result into non-working configuration. Make another backup before and save into another location to restore the PBX or reinstall it, if crashed.
  3. Tony69
    Jun 23, 2017
    Thank you.
