DN status / Outbound caller id
Discussion in 'Windows' started by stefferd, Feb 29, 2008.
  1. stefferd
    Feb 29, 2008
    Hi there,
    I use build 4132 of 3CX phone client, but when I receive a call, it shows the extention number, not the "outbound caller id", any workarounds for this?
    Also in the softphone's users page, the "dn" column gives me greyed out users, whether they are registered or not, shouldn't you see there if a user's phone is registered (green), unregistered(red) or calling (yellow) ?
    Can I reconfigure things to make this work?
    Thanks,
  2. darrellchapman
    Nov 26, 2007
    268
    I've reported the caller ID issue as a bug but there is no telling whether 3CX will fix in the next release.
    The extension status is available in the paid versions of the 3CX Server. If you have a paid license, make sure it's been successfully applied.
    Darrell Chapman
