DND Allowing Intercom Calls
Discussion in '3CX Phone System - General' started by DetroitRadiant, Dec 21, 2017.
Tags:
  1. DetroitRadiant
    Dec 21, 2017
    We have 3CX v. 15.5 and Yealink T-48G phones. The Yealink phones have a DND button, and when pressed, the DND icon shows on the phone and the presence indicators show a red square for Do Not Disturb. However, if you are on DND, someone can still intercom to your phone and it will come through instead of returning a busy indicator. I cannot figure out how to get it to block intercom calls as well.
    The 3CX system has dial codes that can be used. If we use those, the phones do not display the DND icon, but the presence indicator goes to a red square with a white line through it. This mode does NOT allow intercom calls to come through, however, it's not as convenient for people to use and they forget to take it off because the phone doesn't show any icon indicating they're in DND mode.
    Without having to use both methods every time someone goes to lunch, etc., does anyone know how to get the built in Yealink DND to block intercom calls, too?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi DetroitRadiant,
    I too have see different behavior on the desktop phone settings to the Client. Where I have not tested Intercom specifically (so cannot confirm if this is an isolated case) I can at least offer you some points to resolve this, I would look at either:
    * Disabling that DND button on the Yealink (this would be a custom template setting most likely) you would need to be familiar with the editing of configuration files.
    * Set up a custom Speed dial using the dial code for DND (default being *61 for ON *60 for OFF) and encourage people to use this instead.
    * Or even easier still I would disable the setting "Can intercom" under Extension >> Rights or Extension groups >> Group rights.
    This should give you enough to by-pass this issue.
    DetroitRadiant likes this.
  3. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    You also may find value in posting on Yealink's forums. Though, they've seemed to have hidden the forums a bit, and I'm not sure why. http://forum.yealink.com/forum/
    Usually take a fully day to get a response, but they're quite helpful.
  4. DetroitRadiant
    Dec 21, 2017
    I can't disable the intercoms because the system is configured specially so that internal calls to an extension go to an intercom and external calls ring. We do use the intercom feature, but we just don't want it coming through when someone is on DND because sometimes the front office doesn't check the presence indicators before sending a call.
  5. eddv123
    Aug 15, 2017
    1,218
    174
    I would look at my first two points then if disabling Intercom is not an option.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @DetroitRadiant
    This sounds strange. Let us investigate this issue and i will get back to you
