DND Prompt
Discussion in 'Ideas' started by narkumas, Apr 12, 2017.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    I am disappointed about the DND Options in forwarding rules:
    for DND I can forward a call or end call.
    It would be very helpful if there was an additional option: play DND-prompt
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Why not use actual forwarding rules - forward to cell, voicemail, another extension, etc.
    Sounds like you are using *6 codes instead of *3 codes.
    Maybe I am way off base.
