DNIS in VAD
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Jan 16, 2014.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What setting in 3CX needs to be changed so that the DNIS in the IVR shows the DID originally dialed instead of the extension of the IVR?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Shahzad,
    You can get that information using the 3CX Call Control API (http://www.3cx.com/blog/docs/call-control-api/) from a DLL (and call that DLL from an external code execution component).
    The code you need to use could be something like this:
    Code:
        public string GetOriginalDestination(string ani, string dnis)
          DN dn = PhoneSystem.Root.GetDNByNumber(dnis);
          ActiveConnection[] activeConnectionArray = dn.GetActiveConnections();
          foreach (ActiveConnection activeConnection in activeConnectionArray)
            if (activeConnection.ExternalParty == ani) return activeConnection.DialedNumber;
          return String.Empty;
    Hope the information helps.
    Kind regards.
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Will that code not work if there are multiple connection in the IVR at the same time?
  5. VAD_Support
    Aug 6, 2009
    690
    If the calls are from different ANIs, then it will work. If you have many calls from the same ANI, then you will need to also check the date and time of the call in order to determine yours...
  6. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Modified Code to avoid doing a loop
    Code:
                var activeConnection = activeConnectionArray.FirstOrDefault(ac => ac.ExternalParty == ani);
                if (activeConnection == null)
                else
  7. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    The dialed number property on the object is BLANK.
    Is there something in the SIP settings for the Trunk that has to be set for the value to show up?
  8. VAD_Support
    Aug 6, 2009
    690
    I've been doing some tests, and maybe you need to look into the AttachedData property. That property is a collection of information related to the call, try with that property.
  9. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    See screenshot attached for Visual Studio watch on the entire ActiveConnection object.
    The attached data doesn't have it either.
  10. VAD_Support
    Aug 6, 2009
    690
    You may need to adjust the inbound parameters for your trunk. Try changing the values for the fields "To: User Part" or "To: Display Name". That could change the value 10002 in the screenshot to the dialed number.
  11. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    We checked and we already have it set to "CalledNum".
    What else should it be set to?
  12. VAD_Support
    Aug 6, 2009
    690
    Well it depends on how you're receiving the call from your trunk, but you may try with "CalledName" in case that field has the phone number. You're saying that it is confiugred with CalledNum, but currently you're receiving the 3CX port number. Try with that, or send a trace of the SIP INVITE message received by 3CX from the trunk.
