DNS Name to register
Discussion in '3CX Phone System - General' started by josephicon, Nov 16, 2007.
  1. josephicon
    Nov 16, 2007
    I dont have a static ip wan address on my 3cx host pc. Would it be possible to connect to a gateway, authenticating using not an IP address but a dns name.
    I have tried doing this by putting the dns name into the field speciffy IP instead of both/internal/external (stun).
    That did not work.
    Any ideas?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    You can do this in many ways on
    http://www.dyndns.org
    http://www.no-ip.org
    and a more..... just register, choose an avaible submain for you to use, download their program, install on pc and insert you log on details and voila.. you will have something like "Joseph.no-ip.org" or something alike...
    Cheers
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    nexVortex can use whatever IP it gets registered to. No need for static unless you want it for other reasons - like an email server.
    I'd be careful with using those services. I tried it a couple years ago and my IP changed so often that it wasn't userful for email.
  4. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    try no-ip.com works fine and its free
    regards
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I use No-IP and DNSExit, both work great. DNSExit is better if you wish DNS features, as I do.
