DNS Requirements
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 1, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Please correct me if I am wrong
    For the 3CX system the only issue reguarding DNS is a resolution of the IP Address of the PC/Server Hosting the 3CX PBX so that only one FQDN A record is at issue.
    Public FQDN resolved by DNS Server on the Internet and Private FQDN resolved by a DNS Server on the Private Network. One A Record each
    In reviewing the Form and Documentation there seems to be a suggested difference between
    External FQDN and Internal FQDN
    and
    Split DNS
    To my mind they are one in the same
    SPLIT DNS is where the IP Address to which a DNS Name resolves is dependent on the location of the client. Local Private Network Side Client DNS entries resolve to a different IP Addres than a Remote Client DNS entry resolves to its public counterpart.
    So I have a PUBLIC DNS Server A record phone.csmi.com that points to my PUBLIC IP address
    and
    A private side DNS Server with an A Record phone.csmi.com that points to the private address of the 3CX server
    If External FQDN and Internal FQDN
    and
    Split DNS
    Are different can someone enlighten me
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    " So I have a PUBLIC DNS Server A record phone.csmi.com that points to my PUBLIC IP address
    and
    A private side DNS Server with an A Record phone.csmi.com that points to the private address of the 3CX server"
    That would be "split DNS" - where a single FQDN points to two addresses, depending on where the DNS query is answered.
    External and Internal would be like this:
    Internal: phone.csmi.local - internal DNS resolver points to private lan IP.
    External: phone.csmi.com - external DNS resolver points to public IP.
  3. petewatterschats
    Jan 19, 2016
    151
    Thanks, that is what I thought
